Backup and Restore Cisco Callmanager 8.6 using SFTP
ttmoney
Fort Knox
Does anyone have a procedure for backing up a Cisco Callmanager 8.6 using WinsCP? I have tried configuring the product, but have had not luck. I have been successful using Globalscape SFTP, but my HQ wants to give WinsCP a try. I would appreciate any help or advice.
Thanks,
Troy
Re: Backup and Restore Cisco Callmanager 8.6 using SFTP
Well, both WinSCP and Globalscape SFTP are just SFTP clients. So the procedure should be the same using either. How do you backup it using Globalscape SFTP?
ttmoney
Fort Knox
Inside of Cisco Disaster Recovery, you have to setup a backup device, which is an SFTP server. You have to provide an IP, username and password. The backup device fails to be created using WinsCP. When using Globalscape, I put in the same information and it succeeds. Globalscape also runs as a service. I do have WinsCP up and running on my desktop when I try to connect to it, but have had no luck getting a successful backup device created. I was hoping someone who was using WinsCP to backup Cisco Callmanager could give me a few hints as to how they were successful.
Aren't you using Globalscape SFTP server? WinSCP is SFTP client!
