Trouble in SessionRemoteException
zofo
Mexico
Hi
I use WINSCP in C#
need send one file to remote machine, i have to the next code
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using WinSCP;
namespace Envio_RecepcionSFTP
    class envioSFTP
        public int sendSFTP()
            try
                // Setup session options
                    Protocol = Protocol.Sftp,
                    HostName = "192.168.x.xx",
                    UserName = "user",
                    Password = "user",
                    PortNumber= xxx,
                    SshHostKeyFingerprint = "ssh-rsa 1024 b1:af:d9:3f:27:8e:22:e0:b8:88:32:xx:xx:xx:xx:xx"
                    // Connect
                    session.Open(sessionOptions);
                    // Upload files
                    transferOptions.TransferMode = TransferMode.Binary;
                    TransferOperationResult transferResult;
                    transferOptions.FilePermissions = null;
                    transferOptions.PreserveTimestamp = false;
                    transferResult = session.PutFiles(@"C:\XML\Enviar\*", "/", false, transferOptions);
                    // Throw on any error
                    transferResult.Check();
                    // Print results
                    foreach (TransferEventArgs transfer in transferResult.Transfers)
                        Console.WriteLine("Upload of {0} succeeded", transfer.FileName);
                return 0;
            catch (Exception e)
                Console.WriteLine("Error: {0}", e);
                return 1;
this code works fine, but i need send a file to the other path for example
"transferResult = session.PutFiles(@"C:\XML\Enviar\*", "/R", false, transferOptions);"
when i try this, my code has the follow exception
+$exception {WinSCP.SessionRemoteException: Cannot overwrite remote file '/R'.
Press 'Delete' to delete the file and create new one instead of overwriting it. ---> WinSCP.SessionRemoteException: Permission denied.
Error code: 3
Error message from server: Permission denied
--- Fin del seguimiento de la pila de la excepción interna ---
en WinSCP.OperationResultBase.Check()
en Envio_RecepcionSFTP.envioSFTP.sendSFTP() en C:\Desarrollo_xxxx\Pruebas\Envio_RecepcionSFTP\Envio_RecepcionSFTP\envioSFTP.cs:línea 39}
System.Exception {WinSCP.SessionRemoteException}
That path exist on the remote machine, but i cant write on that... i hope anyone can help me
thanks a lot
Reply with quote E-mail
