WinSCP is duplicating file content
guzh
I'm experiencing a weird bug. When I upload single files all content inside those files get duplicated.
E.g. I'm uploading a file with 250 lines, the remote file gets 500 lines. If I try to edit the remote file while inside WinSCP it gets 1000 lines etc..
The WinSCP version I'm using is 5.5.3 build 4214.
Re: WinSCP is duplicating file content
Please attach a full log file showing the problem while uploading (using the latest version of WinSCP).
Does this happen always or only when remote file already exists? Does it actually duplicate the contents or append new contents at the end of existing file?
