problem with automatic synchronizing
Mahdi Bashiri
Hi
i have problem with autpmatic synchronizing script to remote site and also need to delete source file in local directory after successful transfer to remote site as below command line, but i think somethings goes wrong, please let me know?
synchronize remote -filemask=*.ccti D:\IscFtp\ACH\input ACH\input -criteria=size -delete
and output is :
'ACH\input/IR340200000000100012643002000000009.ccti' deleted
Error deleting file 'ACH\input/IR390200000000100008663002000000012.ccti'.
Access is denied.
(A)bort, (R)etry, (S)kip, Ski(p) all: Skip
Regards,
Mahdi
Re: problem with automatic synchronizing
First, replace backslash with slash in your remote file path, i.e. ACH\input => ACH/input.
Then, attach a full log file showing the problem (using the latest version of WinSCP).
