No login
WAS
No login
A new user to the program......"The requested name is valid and was found in the database, but it does not have the correct associated data being resolved for." What does this mean please?
I'm not getting anywhere :((
WAS
No Login
found this..... "The usual example for this is a host name-to-address translation attempt which uses the DNS (Domain Name Server). An MX record is returned but no A record—indicating the host itself exists, but is not directly reachable." ...but I'm none the wiser. I think I'm out of my depth with this program. I'll stick to SmartFTP.
Re: No login
So, you able to connect with SmartFTP?
Can you try to disable your firewall temporarily to check if that helps when connecting with WinSCP?
Can you share a log file both from WinSCP and SmartFTP?
