Network error: Software caused connection abort
Hi
I am getting this problem when I am transferring files. It is OK for for smaller files (< 1.5 MB) but anything larger than that will exhibit the problem. It is happening to 2 different transfers, which run on different hosts and with different destinations servers (both provided by third parties) I suspect our proxy server is causing the problem but our network team have not yet identified a problem, are there any settings that can make the transfer more resilient and allow the transfer to continue?
. 2014-04-25 13:13:58.147 --------------------------------------------------------------------------
. 2014-04-25 13:13:58.147 Using SFTP protocol.
. 2014-04-25 13:13:58.147 Doing startup conversation with host.
> 2014-04-25 13:13:58.147 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2014-04-25 13:13:58.256 Type: SSH_FXP_VERSION, Size: 69, Number: -1
. 2014-04-25 13:13:58.256 SFTP version 3 negotiated.
. 2014-04-25 13:13:58.256 Unknown server extension posix-rename@openssh.com="1"
. 2014-04-25 13:13:58.256 Unknown server extension coz-zopts@dovetail.com="0"
. 2014-04-25 13:13:58.256 We believe the server has signed timestamps bug
. 2014-04-25 13:13:58.256 We will use UTF-8 strings for status messages only
. 2014-04-25 13:13:58.256 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2014-04-25 13:13:58.256 Changing directory to "//DTS3.DOWN.G6SUK".
. 2014-04-25 13:13:58.256 Getting real path for '//DTS3.DOWN.G6SUK'
> 2014-04-25 13:13:58.256 Type: SSH_FXP_REALPATH, Size: 26, Number: 16
< 2014-04-25 13:13:58.381 Type: SSH_FXP_NAME, Size: 55, Number: 16
. 2014-04-25 13:13:58.381 Real path is '//DTS3.DOWN.G6SUK'
. 2014-04-25 13:13:58.381 Trying to open directory "//DTS3.DOWN.G6SUK".
> 2014-04-25 13:13:58.381 Type: SSH_FXP_LSTAT, Size: 26, Number: 263
< 2014-04-25 13:13:58.506 Type: SSH_FXP_ATTRS, Size: 13, Number: 263
. 2014-04-25 13:13:58.506 Getting current directory name.
. 2014-04-25 13:13:58.506 Startup conversation with host finished.
< 2014-04-25 13:13:58.506 Script: Active session: [1] DTCCNEW
> 2014-04-25 13:13:58.506 Script: option batch on
< 2014-04-25 13:13:58.506 Script: batch on
> 2014-04-25 13:13:58.506 Script: option confirm off
< 2014-04-25 13:13:58.506 Script: confirm off
> 2014-04-25 13:13:58.506 Script: ls /+recfm=vb,mode=text,lrecl=27000
. 2014-04-25 13:13:58.506 Listing directory "/+recfm=vb,mode=text,lrecl=27000".
> 2014-04-25 13:13:58.506 Type: SSH_FXP_OPENDIR, Size: 41, Number: 523
< 2014-04-25 13:13:58.600 Type: SSH_FXP_HANDLE, Size: 13, Number: 523
> 2014-04-25 13:13:58.600 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2014-04-25 13:13:58.694 Type: SSH_FXP_NAME, Size: 119, Number: 780
> 2014-04-25 13:13:58.694 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< 2014-04-25 13:13:58.787 Type: SSH_FXP_STATUS, Size: 28, Number: 1036
< 2014-04-25 13:13:58.787 Status code: 1
> 2014-04-25 13:13:58.787 Type: SSH_FXP_CLOSE, Size: 13, Number: 1284
< 2014-04-25 13:13:58.787 Script: -r--r--r-- 0 0 Dec 30 0:00:00 1899 recfm=vb
< 2014-04-25 13:13:58.787 Script: -r--r--r-- 0 0 Dec 30 0:00:00 1899 mode=text
< 2014-04-25 13:13:58.787 Script: -r--r--r-- 0 0 Dec 30 0:00:00 1899 lrecl=27000
> 2014-04-25 13:13:58.787 Script: option transfer binary
< 2014-04-25 13:13:58.787 Script: transfer binary
> 2014-04-25 13:13:58.787 Script: lcd \\sgbmdfs\EMEA\GB\Apps\FMIT\DTCCDoddFrank\Processing\
< 2014-04-25 13:13:58.787 Script: \\sgbmdfs\EMEA\GB\Apps\FMIT\DTCCDoddFrank\Processing
> 2014-04-25 13:13:58.787 Script: put DTS3.UP.G6SUK.S60280.csv //DTS3.UP.G6SUK.S60280
. 2014-04-25 13:13:58.803 Copying 1 files/directories to remote directory "//"
. 2014-04-25 13:13:58.803 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: N (102400); CalcS: No; Mask: DTS3.UP.G6SUK.S60280
. 2014-04-25 13:13:58.803 TM: B; ClAr: No; CPS: 0; InclM:
. 2014-04-25 13:13:58.803 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2014-04-25 13:13:58.803 File: "DTS3.UP.G6SUK.S60280.csv"
. 2014-04-25 13:13:58.803 Copying "DTS3.UP.G6SUK.S60280.csv" to remote directory started.
. 2014-04-25 13:13:58.803 Binary transfer mode selected.
. 2014-04-25 13:13:58.803 Opening remote file.
> 2014-04-25 13:13:58.803 Type: SSH_FXP_OPEN, Size: 47, Number: 1539
< 2014-04-25 13:13:58.881 Type: SSH_FXP_STATUS, Size: 24, Number: 1284
. 2014-04-25 13:13:58.881 Discarding reserved response
< 2014-04-25 13:13:59.037 Type: SSH_FXP_HANDLE, Size: 13, Number: 1539
> 2014-04-25 13:13:59.053 Type: SSH_FXP_WRITE, Size: 4121, Number: 2054
. 2014-04-25 13:14:31.866 Network error: Software caused connection abort
. 2014-04-25 13:14:31.866 Connection was lost, asking what to do.
. 2014-04-25 13:14:31.866 Asking user:
. 2014-04-25 13:14:31.866 Network error: Software caused connection abort ()
I have tried with the latest version and get the same problem.
Re: Network error: Software caused connection abort
WinSCP should at least try to reconnect and resume the transfer. Does it?
