Dir Sync: WinSCP.SessionRemoteException for remote path
sebastian.hockmann
Deutschland
Hello.
i would like to mirror / sync a FTP directory to a local path.
I'm using the current version of the .NET library.
This works fine on my developer machine. But on the production machine
i get the following error:
WinSCP.SessionRemoteException: Error retrieving file list for "\\group.jenoptik.corp\Global\OS\OES\PS\Triptis\Files\PRODUKTION\AVT\Projekte\CMOSIS\01_ARF\
I can access this path on the production machine.
I attached the logs (debug+session)
Any ideas for the root cause ?
Thanks,
Sebastian
P.D:
Here is my C# coding:
public class FTPSync
public int syncronizeDirectory( string hostname, string username, string password, string localpath, string remotepath)
//set connection parameters
WinSCP.SessionOptions sessionOptions = new SessionOptions();
sessionOptions.Protocol = WinSCP.Protocol.Ftp;
sessionOptions.HostName = hostname; //"as-ftp-e01.jenoptik.corp";
sessionOptions.UserName = username; //"JOPS-CMOSIS";
sessionOptions.Password = password; //"1234";
sessionOptions.FtpMode = FtpMode.Passive;
WinSCP.Session session = new Session();
session.DebugLogPath = @"d:\debuglog.txt";
session.SessionLogPath = @"d:\sessionlog.txt";
session.
try
using (System.IO.StreamWriter file = new System.IO.StreamWriter(@"d:\auth.txt"))
string svc_username = System.Security.Principal.WindowsIdentity.GetCurrent().Name;
file.WriteLine(svc_username);
//change user context
using (new Impersonator ("service.wmistest","CORP","1234"))
//log user context
session.FileTransferred += FileTransferred;
// Connect
session.Open(sessionOptions);
string localpath = @"\\group.jenoptik.corp\Global\OS\OES\PS\Triptis\Files\PRODUKTION\AVT\Projekte\CMOSIS\01_ARF";
string remotepath = "01_ARF";
// Synchronize files to local directory, collect results
SynchronizationResult synchronizationResult;
synchronizationResult =
session.SynchronizeDirectories(
WinSCP.SynchronizationMode.Local, localpath, remotepath, false);
//throw on any error
synchronizationResult.Check();
return 0;
catch (Exception e)
Console.WriteLine("Error: {0}", e);
using (System.IO.StreamWriter file = new System.IO.StreamWriter(@"d:\error.txt"))
file.WriteLine(e);
//errormessage = e.Message;
return -1;
private static void FileTransferred(object sender, TransferEventArgs e)
if (e.Error == null)
Console.WriteLine("Upload of {0} succeeded", e.FileName);
else
Console.WriteLine("Upload of {0} failed: {1}", e.FileName, e.Error);
if (e.Chmod != null)
if (e.Chmod.Error == null)
Console.WriteLine("Permisions of {0} set to {1}", e.Chmod.FileName, e.Chmod.FilePermissions);
else
Console.WriteLine("Setting permissions of {0} failed: {1}", e.Chmod.FileName, e.Chmod.Error);
else
Console.WriteLine("Permissions of {0} kept with their defaults", e.Destination);
if (e.Touch != null)
if (e.Touch.Error == null)
Console.WriteLine("Timestamp of {0} set to {1}", e.Touch.FileName, e.Touch.LastWriteTime);
else
Console.WriteLine("Setting timestamp of {0} failed: {1}", e.Touch.FileName, e.Touch.Error);
else
// This should never happen with Session.SynchronizeDirectories
Console.WriteLine("Timestamp of {0} kept with its default (current time)", e.Destination);
Re: Dir Sync: WinSCP.SessionRemoteException for remote path
Can you access it even as CORP\AS-ESB-01T$?
