SU to other user and resume ?!
buzz
Hi there ...
cool program but is it possible
to SU to another user when im connected.
For sec. reasons all our boxes are only allowed
to ssh to one user.
Secord, if or when is resume possible in WinSCP ?
SCP for console works fine, why not put it in
WinSCP ?
//Buzz
Re: SU to other user and resume ?!
I've tried this, but at least on servers I have access to, SU requires TTY in standard input, which is not case of WinSCP.
SCP for console works fine, why not put it on
WinSCP ?
Which console SCP supports resuming? AFAIK, SCP does not support resuming at all!
First, I'm not a su expert but isn't it possible to add your user to sudoers so it wont require a password to su to root?
Second, so SCP doesn't support file resumes? If so, that is a major flaw in the SCP protocol :( Maybe it is possible to emulate the resume behaviour by executing a command line like `cut file|tail -c "the remaining bytes"` and save the output from stdout to the file? I don't know if that is possible with SCP but if it is, then SCP doesn't need to know if we are trying to resume a file or not.
Does it supports canceling requests on file transferes then? I know its on the TODO but is it possible?
I don't know, I don't use SU. If it is possible, than you can try to execute SU via console (new feature of WinSCP 2.2). Please let me know if you succeed.
Second, so SCP doesn't support file resumes? If so, that is a major flaw in the SCP protocol :( Maybe it is possible to emulate the resume behaviour by executing a command line ...
Sure, I may. Someday :-)
It does not.
I added this to my /etc/suauth:
root:myusername:NOPASS
Which allows me to su to root without and password typing but a real TTY is still a requirement :(
$ su
su: must be run from a terminal
>>possible?
>It does not.
The SCP abilities is so limited :cry:
