upload hangs with timeout
weholei
Hi
OS = Win7
For about two months, the upload fails with timeout.
The download works
It does not matter which version of Winscp I use.
The upload is disturbed to all servers no matter which version of Linux, whether LAN or via Internet
What I do not understand is that even a restore the system partition of an approximately 2 years old image shows the same problem
. 2014-04-17 23:27:53.597 File: "C:\Users\xxxxx\Documents\Krol olch.xxx"
. 2014-04-17 23:27:53.597 Copying "C:\Users\xxxxx\Documents\Krol olch.xxx" to remote directory started.
. 2014-04-17 23:27:53.597 Binary transfer mode selected.
. 2014-04-17 23:27:53.597 Checking existence of file.
> 2014-04-17 23:27:53.597 Type: SSH_FXP_LSTAT, Size: 46, Number: 3335
< 2014-04-17 23:27:53.597 Type: SSH_FXP_STATUS, Size: 24, Number: 3076
. 2014-04-17 23:27:53.597 Discarding reserved response
< 2014-04-17 23:27:53.643 Type: SSH_FXP_STATUS, Size: 29, Number: 3335
< 2014-04-17 23:27:53.643 Status code: 2
. 2014-04-17 23:27:53.643 Checking existence of partially transfered file.
> 2014-04-17 23:27:53.643 Type: SSH_FXP_LSTAT, Size: 55, Number: 3591
< 2014-04-17 23:27:53.690 Type: SSH_FXP_STATUS, Size: 29, Number: 3591
< 2014-04-17 23:27:53.690 Status code: 2
. 2014-04-17 23:27:53.690 Opening remote file.
> 2014-04-17 23:27:53.690 Type: SSH_FXP_OPEN, Size: 71, Number: 3843
< 2014-04-17 23:27:53.737 Type: SSH_FXP_HANDLE, Size: 13, Number: 3843
> 2014-04-17 23:27:53.737 Type: SSH_FXP_WRITE, Size: 4121, Number: 4358
. 2014-04-17 23:28:37.308 Waiting for dispatching send buffer timed out, asking user what to do.
. 2014-04-17 23:28:37.308 Asking user:
. 2014-04-17 23:28:37.308 Host is not communicating for 15 seconds.
. 2014-04-17 23:28:37.308 Wait for another 15 seconds? ()
. 2014-04-17 23:28:39.320 Attempt to close connection due to fatal exception:
* 2014-04-17 23:28:39.320 Terminated by user.
. 2014-04-17 23:28:39.320 Closing connection.
. 2014-04-17 23:28:39.320 Sending special code: 12
. 2014-04-17 23:28:39.320 Sent EOF message
. 2014-04-17 23:28:39.320 Connection was lost, asking what to do.
. 2014-04-17 23:28:39.320 Asking user:
. 2014-04-17 23:28:39.320 Terminated by user. ()
* 2014-04-17 23:28:40.506 (ESshFatal) Terminated by user.
* 2014-04-17 23:28:40.506 Copying files to remote side failed.
who has an idea how to solve the problem?
Thank you
Reply with quote E-mail
peterfh
Still unsolved
I'm having the same problem in Win7. Downloads work ok but uploads hang out, specially if I try to transfer an image.
I have switched to binary mode, tried with passive and non passive connections, set max concurrent connections to 1, disabled firewall and antivirus, tried various versions (5.1, 5.5). But nothing, I always get the same behaviour... freeze on upload.
Re: Still unsolved
