Uploading changes in default Editor doesn't work sometimes
franc
franc avatar
Hello
this is a weird bug, I have only since the WinSCP version 5.5.2
I am on Windows XP (SP3, 32).
I use normally the multitabbed Editor EditPad Pro, version 7.3.1
Often I edit files from my SSH-connected Ubuntu Server with SFTP in this editor.
But sometimes, it happend now the second time, I wonder why the changes are not visible, but I did save them, no error message.
Reason is, that WinSCP doesn't upload it again.
So I tried with a single window editor, TedNPad, but still the same.
It will work again, I thought, when I restart WinSCP, but this is a bit annoying, because I have three WinSCP tabs and files open.
But no, this doesn't still not work, when restarted WinSCP.
I tried to upload big changes, so WinSCP should be busy a little and I can look into the Queue, there I see strange Progress Completed and Transferred 0 B, after a short while Queue closed.
I don't think it is possible to log WinSCP, because this bug appears not often, so the logfile could be gigabytes.
Thank you.
frank
Description: Queue WinSCP 5.5.2
franc
franc avatar
This is a real problem.
I cannot trust to editing through WinSCP anymore.
I wonder why things not working and again this doesn't upload!
I don't know what this is, the only way then is, to delete file, and recreate it with same content. This work then a while.
What could that be?
Re: Uploading changes in default Editor doesn't work sometimes
franc
franc avatar
Can you send me a version, where there is all private data in the debug log excluded?
I find a lot of things like:
[Password=A35C795D0D2E333...]
in this debug-logfile.
I guess till the bug will appear, it could take some time, and in the end, I have a debug protocol of 100 MB or more.
It will be not possible for me to surely delete all private data in this log (like I tried last time).
The log will be filled with passwords, I cannot send these out, sorry.
