Heartbleed bug in OpenSSL
CWincentsen
I just learned of what is considered to be a serious bug in several versions of OpenSSL. I'm concerned that this might/probably affects some recent installations of WinSCP and wanted to alert development to the issue, in case you weren't aware of it already.
This link connects to detailed information about the bug and which versions of OpenSSL are affected... https://heartbleed.com/
Re: Heartbleed bug in OpenSSL
This bug is tracked here:
https://winscp.net/tracker/1151
We are working on a fix.
It actually affects even clients:
https://security.stackexchange.com/q/55119/43677
Though obviously it is a way more difficult to abuse this on a client side (than on a server side).
Note that OpenSSL is used with FTP over TLS/SSL only. Majority (about 98%) of WinSCP users use SSH (SFTP/SCP) and plain FTP only and are NOT affected!
Midnitelouie
WinSCP 5.5.3?
Showing on the bug report that you've got it fixed in 5.5.3, but no location as to being able to download the package?
Re: WinSCP 5.5.3?
It's not released yet. We plan to release 5.5.3 in few days.
Iruwen wrote:
Yes it does, but not SSH (and thus SCP/SFTP) clients because SSH obviously doesn't use TLS heartbeats, so WinSCP and other SSH clients shouldn't be affected at all?
That's true. But WinSCP is also TLS/SSL client, when used with FTP over TLS/SSL. Majority (about 98%) of WinSCP users use SSH (SFTP/SCP) and plain FTP only and are NOT affected!
Craig
WinSCP Version Number
While I am aware of the registry key containing the version number of WinSCP:
reg query "HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\winscp3_is1" /v "DisplayVersion"
Is there a way to output the version number at the command line from winscp.exe?
I am looking for the most efficient and effective way of finding vulnerable versions en masse on large numbers of systems.
Craig
Re: WinSCP Version Number
C:\test>WinSCP.com /?
WinSCP, Version 5.5.2 (Build 4130)
Copyright (c) 2000-2014 Martin Prikryl
Craig
Thank you. I was boneheadedly trying winscp.exe and overlooking winscp.com.
Thanks for the quick reply.
Craig
CoreyB
WINSCP.EXE to FTPS site
If I am using WINSCP.EXE command line to connect to an FTPS site, do I need to upgrade to new version due to HeartBleed?
schaitel
What about the .NET interop?
We use the .NET interop DLL in SSIS packages for FTP and SFTP, is installing version 5.5.3 enough or do we need to also register and upgrade to the latest Interop DLL?
Re: WINSCP.EXE to FTPS site
Yes, you should upgrade. Actually you should always upgrade, when there's a new version available.
Re: What about the .NET interop?
What do you mean by ".NET interop DLL"? Do you mean WinSCP .NET assembly? You always need to upgrade that along with WinSCP. You cannot use different versions of WinSCP and WinSCP .NET assembly together.
