Timeout waiting for external console to complete the command
psharma
India
I am using WINSCP version 5.1.3.
I am using .net library.
My upload/download automation application has been running smoothly for months.
But all of sudden it has started crashing.
It may crash 4 times in 4 hours and sometimes it crash only once in 12 hours.
This happens for small files as well.
Following is the error message which I get;
Now I have increased the connection timeout to as much as 6 mins (360 sec), but not helping.
I tried setting/enabling "Keepalive" as well, but did not help.
Finally I have now selected the option "Optimize connection buffer size"; not sure if that is going to help.
The connection timeout is still set as 6 mins, though I have removed the keepalive option.
I am not using "Process" rather I am using session.
Please help.
Re: Timeout waiting for external console to complete the command
psharma
OOps, What I shared is WER log report and not WINSCP; I will share the correct one. - Pravin
psharma
I have emailed you the WinSCP log. Request you to please analyze and share your feedback. - Pravin.
