getting started with WinSCP
boe
How do i start using this tool, i just heard about this tool a few ago and downloaded it, but i can't seem to get it going.
I have a smoothwall firewall box that i would like to upload some domain names to but i can't seem to do, so i need all the help i can get.
Thank You
Davfin
ajacobs
Re: getting started with WinSCP
And what's the problem? Any error message? Or log file?
I have this same problem. I type in the name of my firewall, and user name and password, all other choices in WinSCP are default. The error is "Host Does not exist." I have ssh enabled in my Smoothwall, and I use port 222, which is the port used by Smoothwall. I have a valid user name and password. I tried with the name of my smoothwall and the IP address.
With what clients are you able to connect to your firewall? Can you try to connect with Putty?
nick
problem is there is no HELP file for numpty like me, who knows nothing about ssh file transfer. but in defence of my own complaint.
It worked , I got a file across! F knows how....
