two ask for powershell script
rvjhon
I want use a Powershell script for download file on few serveur (20-30).
Can i use WinSCPnet.dll whitout $sessionOptions.SshHostKeyFingerprint ?
And can i read on a file HostName and password ... ?
I have test a many solution with Get-Content and Foreach-Object.
and now i have no idea for creating this script
Thanks so much
King Regards
Jhon
My script:
try
[Reflection.Assembly]::LoadFrom("WinSCPnet.dll") | Out-Null
ForEach ($liste_srv in Get-Content "z:\projet_enable\liste_serveur.txt")
($liste_mdp in Get-Content "z:\projet_enable\liste_mdp.txt")
($liste_ssh in Get-Content "z:\projet_enable\liste_ssh.txt")
$sessionOptions.HostName = $liste_srv
$sessionOptions.UserName = "root"
$sessionOptions.Password = $liste_mdp
$sessionOptions.SshHostKeyFingerprint = $liste_ssh
try
$session.GetFiles("/home/gconf/*.gz", "C:\Users\adm-l2b-jherve\test\*").check()
finally
# Disconnect, clean up
$session.Dispose()
exit 0
catch [Exception]
Write-Host $_.Exception.Message
exit 1
ForEach ($system in Get-Content "liste_serveur.txt")
Write-Host $system
Write-Host " "
exit 1
Re: two ask for powershell script
If you do not care about security you can use SessionOptions.GiveUpSecurityAndAcceptAnySshHostKey.
Do you mean if you can read hostname and password from a file? WinSCP .NET assembly cannot do this directly, but implementing this in PowerShell should be pretty easy. That's out of scope of the forum though.
rvjhon
Sorry i dont know use this value.
Where i put this value $sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey
regards mister
$srv = Get-Content "z:\projet_enable\liste_serveur.txt"
$mdp = Get-Content "z:\projet_enable\liste_mdp.txt"
[switch] $IgnoreHostKey = $false
for ($i = 0; $i -le $srv.count-1; $i++){
write-host "etape 1" $srv[$i]
$sessionOptions.HostName = $srv[$i]
$sessionOptions.Password = $mdp[$i]
$sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey = $IgnoreHostKey
write-host "etape 2" $srv[$i]
try
write-host "etape 3 Ligne $i correspondant" $srv[$i]
write-host "================="
finally
$session.Dispose()
