Benefits of using NET Assembly as opposed to just Powershell
jsb2210
I was wondering if I could get some reasons as to why the .NET Assembly with Winscp is better to use than Winscp and PowerShell? I have been scripting in PowerShell for a little while, but I'm not a coder or developer.
Re: Benefits of using NET Assembly as opposed to just Powershell
In you skip WinSCP .NET assembly, you need to code in PowerShell all the the assembly does: Running WinSCP process, feeding its input, capturing and interpreting its output, detecting crashes, errors, etc.
