How Compile WinSCP in Borland Builder C++ 6?
Argone
Please help,
I`m triying to compile your source code in borland builder c++ 6 but I can not compile it. Can you say me, step to step, how compile it.
I need acces to Sftp from me ouw client. Thanks
Argone
Re: How Compile WinSCP in Borland Builder C++ 6?
There is readme file in source code package. It says that only you need to compile WinSCP is:
To build WinSCP from source by yourself, type 'make' in root
folder of source code package (directory where 'makefile' file resides).
To build WinSCP you need Borland C++ Builder 6 (at least Professional).
srinivasan
chennai
dear argone,
I want to compile source code of winSCP. Kindly guide me,which editor should i use to compile WinSCP & How to compile WinSCP process step by step.I Look forward to hearing from you.
thanks in advanced
