How to set TLS/SSL options
How can i set the settings displayed here:
https://winscp.net/eng/docs/ui_login_tls
I have a connection problem using the .NET assembly (SSL handshake), when using the GUI i can force to use SSL 3.0 for both minimum and maximum and then the connection succeeds, but still unable to connect using the assembly
