Host Key wasn't verified!
SikhSuperman
Hello - I believe I got everything working, but the issue is that I get the above error with 'Authentication Failed' in my .NET assembly. When I first got the ssh host key fingerprint, I didn't check the box to "cache the key and always trust this host". So, i assume that the host didn't get added to my host's file??
Basically, what do I need to do to verify the key again either through scripting or GUI? By the way, when I use 'open <ip address of sftp> -host key ssh rsa xx:xx:xx, etc, I get a 'Host does not exist' and winscp attempts to connect in 4s. I am using 5.x of winscp.
Any help is appreciated.
SS
Re: Host Key wasn't verified!
This is irrelevant (unless you set Session.DefaultConfiguration = false, what is not recommended).
What value do you set to SessionOptions.SshHostKeyFingerprint?
You do not. You need to set SessionOptions.SshHostKeyFingerprint correctly.
It should be open <ip address of sftp> -hostkey="ssh-rsa 1024 xx:xx:xx"
SikhSuperman
Thanks Martin - It turned out that my ssh key had an incorrect number in it. :oops: But, I ran into this error:
WinSCP.SessionLocalException: WinSCP process terminated with exit code 3 and output "", without responding (response log file C:\Users\TEMP\AppData\Local\Temp\wscp0AC0.02181261.tmp was not created). This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.
   at WinSCP.Session.Open(SessionOptions sessionOptions)
   at <project>.AppCode.SyncBL.SendFTPFile(String filename, String fileNamePath)
From what I have reading on winscp.com I needed to upgrade. So, I went ahead and upgraded my assembly to 5.5.2 from 5.1.7. Is this all that needs to be done?
Thanks!
SS
SikhSuperman
Martin - it looks like this error was resolved when I upgraded. It's hard for me to test, as I don't have physical access to the environment. I rely on log files to troubleshoot.
But, I did end up received the following error:
Could not load file or assembly 'WinSCP, Version=1.0.7.3446, Culture=neutral, PublicKeyToken=b5f19f5762436b89' or one of its dependencies. The module was expected to contain an assembly manifest.
Again, from my reading, it looks like that I am targeting a 64bit when the WinSCP dll is 32bit. I've made the change in my application ('AnyCPU' to 32bit) and will follow up if I was successful.
Thanks again for the help here!!
SS
SikhSuperman
Just to provide an update in case somebody else runs into issues. I have to say that the 'manifest' error really just went away after doing a clean solution/rebuild project. I believe the winscp assembly is compiled against 'Any Cpu' so, changing between 32bit/64bit should be irrelevant. But, I'm sure Martin will chime in and correct me if I'm wrong.
So, I am compiling my project against 'Any Cpu' and so far the initial test seemed to work.
Thanks!
SS
