unable to delete a directory with square brackets in name
Hi all,
I am trying to write a Powershell script that automatically deletes empty directories on our ftp server. I don't have any direct access to the server on which the directories reside - I can only access them via ftp. For this reason, I have written a powershell script that uses winscp to (try to) delete the empty directories.
However, I have a problem, in that many of the directories on the server have square brackets in the directory name.
For example, the directory name might be called:
[a]153432
There are lots of these directories, hence my desire to write a script to delete them.
This occurs because they've been created by a program that uses a number to create the directories it requires.
In order to work on this program, I created an empty directory
/latest/[b]test
My program goes like this:
<PROGRAM>
# program to test deletion of directories with square-brackets in the name.
$HOSTNAME="myftpservername"
$USERNAME="myftpusername"
$PASSWORD="myftppassword"
$DLL_LOCATION="C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
$LOCAL_DIRECTORY="C:\testdir\extended\baseroot"
# Load WinSCP .NET assembly
[Reflection.Assembly]::LoadFrom($DLL_LOCATION) | Out-Null
# Session.FileTransferred event handler
try
$sessionOptions.Protocol = [WinSCP.Protocol]::ftp
$sessionOptions.HostName = $HOSTNAME
$sessionOptions.UserName = $USERNAME
$sessionOptions.Password = $PASSWORD
try
# Connect
$remoteFileWithUnixPath = "/latest/[b]test"
$removalResult = $session.RemoveFiles($remoteFileWithUnixPath)
if ($removalResult.IsSuccess)
Write-Host ("Removal of remote file {0} succeeded" -f $remoteFileWithUnixPath)
else
Write-Host ("Removal of remote file {0} failed" -f $remoteFileWithUnixPath)
finally
# Disconnect, clean up
$session.Dispose()
exit 0
catch [Exception]
Write-Host $_.Exception.Message
exit 1
</PROGRAM>
When I run it, it displays the following message:
PS C:\Users\dbuddrige\Documents\dps> .\delete-squarebracket-dir.ps1
Removal of remote file /latest/[b]test succeeded
However, the directory is not deleted.
BUT, if I change the directory name [and the variable $remoteFileWithUnixPath] to something like
/latest/foo
And then re-run the program, it delete's the directory /latest/foo just fine.
Does anyone have any ideas what I need to do to get this to work?
thanks heaps,
David Buddrige
[a]153432
/latest/[b]test
<PROGRAM>
try
try
# Connect
else
finally
$session.Dispose()
exit 0
catch [Exception]
exit 1
</PROGRAM>
/latest/foo
thanks heaps,
David Buddrige
