transfer configuration
bmcnish
I am running version 5.1.5 and need to export my configurations to another computer. I looked at the instructions but the Tools menu at the login dialog does not have an Export option. please advise how I can accomplish this.
Re: transfer configuration
You should upgrade to a latest version of WinSCP.
Or in your version, you can use Export button on Preferences dialog.
