exculding a file or directory in c#
sharif
Bradford
I am using synchronisation from linux to windows thruogh c# code. The problem i am facing is some files names in linux are not supported in windows. this synchronisation stucks when it get to such files name which is not supported in windows. Now i want to exclude those directories and file names. Can any one please help me.
string path = Server.MapPath("~/Data/");
// Connect
session.Open(sessionOptions);
// Synchronize files
SynchronizationResult synchronizationResult;
synchronizationResult =
session.SynchronizeDirectories(
SynchronizationMode.Local, path, "//fdr/mydat/msgfolder", false);
// Throw on any error
synchronizationResult.Check();
Re: exculding a file or directory in c#
To generate log file, set Session.SessionLogPath. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
