FTPS Explicit TLS .NET Libarary
bgolfer66
United States
Edit: Sorry, user error. I was not setting the SSLHostCertificateFingerPrint before connecting.
Sorry for the rogue posting.
John
Hello, I'm having an issue connecting to a FTPS site using Explicit TLS encryption through the .Net Library through Powershell.
This is a new problem and first time I've tried using FTPS with Explicit TLS. WHen I use the GUI interface, I am able to connect.
When I go through the powershell code, I get an unable to connect exception.
Here is my code:
    $winSCPathDLL = $global:appSettings["WinSCPDLL"]
    $winSCPDLLPath = $winSCPath + $winSCPathDLL
    [Reflection.Assembly]::LoadFrom($winSCPDLLPATH) #| Out-Null
   # Setup session options
   $sessionOptions.Protocol = [WinSCP.Protocol]::ftp
    $sessionOptions.FtpMode = [WinSCP.FtpMode]::passive
    $sessionOptions.FtpSecure = [WinSCP.FtpSecure]::explicittls
   $sessionOptions.HostName = $global:appSettings["FTPHost"]
   $sessionOptions.PortNumber = $global:appSettings["FTPPortNumber"]
   $sessionOptions.UserName = $global:appSettings["FTPUser"]
   $sessionOptions.Password = $global:appSettings["FTPPassword"]
   $session.Open($sessionOptions)  #<<< Exception throw here
When I load the assembly, I get this:
GAC Version Location
False v2.0.50727 D:\ServiceOrders\Script\WinSCP\WinSCPnet.dll
I downloaded the latest .Net DLL today, so I have version 5.5.1.0
The exception details I can get to :
Connection failed.
At D:\Script.ps1:167 char:3
+ $session.Open($sessionOptions)
+ CategoryInfo : NotSpecified: (:) [], SessionRemoteException
+ FullyQualifiedErrorId : SessionRemoteException
I'm sure I must be missing something, but I am at a loss for finding it.
Thank you for the help.
John
bgolfer66
United States
Re: Getting the same problem
Silku wrote:
John, have you got any solution for the above ? I am getting same problem.
Thanks.
I Did. The issue I was having was in setting the SslHostCertificateFingerprint print.
Here is my Powershell code for connecting.
I got the value for the finger print by connecting to the site using the gui,going to the commands menu and choosing "Server/Protocol info"
Hope this helps.
    # Load WinSCP .NET assembly
    # Use "winscp.dll" for the releases before the latest beta version.
    $winSCPath = $global:appSettings["WinSCPath"]
    $sessionOptions.SslHostCertificateFingerprint = $global:appSettings["FTPFingerPrintKey"]
   try
      # Connect
           $yesterday = (Get-Date).AddDays($yesterdayValue).ToString('yyyyMMdd')
           # List of remote folders to check
           $remoteFolders = $global:appSettings["RemotePaths"]
           foreach ($remoteFolder in $remoteFolders.Split(","))
              $remotePath = "/" + $remoteFolder.Trim() + "/*" + $yesterday + "*"
              $localFolder = $localPath + $remoteFolder + "\"
              $TransferResults = $session.GetFiles($remotePath, $localFolder, $false, $transferOptions)
              try
                $TransferResults.Check()
              catch [Exception]
                    $emailBody += "Error Downloading " + $remotePath + ":" + $_.Exception.Message
        $session.Dispose()
[/code]
Silku
Authitication failed
Jon Thanks...but after this when I changed this similar like this.
It says authentication failed :-((( any idea....?
Your help is much much appreciated....eagerly waiting...
Silku
Should I use IP address instead of site address
Don't know if this allows to authenticate, I copied it from server/protocol info only.
bgolfer66
United States
Re: Should I use IP address instead of site address
I would need to see your code.
Silku
Thanks John.
Here it is : I have given write host trap from where it is causing....
Now it is saying "The requested operation requires elevation"...:-((
try
write-host "Begin..............." -foregroundcolor yellow;
[Reflection.Assembly]::LoadFrom("C:\Program Files (x86)\WinSCP\WinSCPnet.dll")
write-host "After assembly...." -foregroundcolor yellow;
write-host "After Open WinSCP.SessionOptions...." -foregroundcolor yellow;
write-host "After Open WinSCP.prtocol...." -foregroundcolor yellow;
write-host "After Open WinSCP.ftpmode...." -foregroundcolor yellow;
$sessionOptions.PortNumber = "22"
$sessionOptions.HostName = "ftp.zzzz.com"
$sessionOptions.UserName = "zzzz"
$sessionOptions.Password = "*****"
write-host "After password...." -foregroundcolor yellow;
$sessionOptions.SslHostCertificateFingerprint = "xx:e3:74:c5:a7:e3:0f:5b:d3:77:6e:bd:58:19:a6:2c:33:e8:fa:ec"
write-host "After Open SslHostCertificateFingerprint ...." -foregroundcolor yellow;
write-host "After new session ...." -foregroundcolor yellow;
try
# Connect
write-host "Before Opening ...." -foregroundcolor yellow;
write-host "After Open Session...." -foregroundcolor yellow;
$localPath = "E:\Apps\"
$remotePath = "/SFTPPourshinsDownload"
$file = "CS_20140703_050427.csv"
# Format timestamp
$stamp = $(Get-Date -f "yyyyMMddHHmmss")
# Download the file and throw on any error
$session.GetFiles(
($remotePath + $file),
($localPath + $stamp + "." + $file)).Check()
finally
# Disconnect, clean up
$session.Dispose()
exit 0
catch [Exception]
Write-Host $_.Exception.Message -foregroundcolor green
#exit 1
$host.enternestedprompt()
write-host "To see the output........." -foregroundcolor yellow;
pause
What line of cause is causing this error? It's definitely not a message from WinSCP.
Silku
After this line
Authentication failed but I can connect through GUI base...
bgolfer66
United States
Nothing looks out of the ordinary to me. I am able to substitute my connection credentials into your code and connect to my server.
whatever is happening is outside my area of expertise. Hopefully a site admin can help you.
Silku wrote:
Thanks John.
try
try
# Connect
# Format timestamp
$session.GetFiles(
finally
$session.Dispose()
exit 0
catch [Exception]
#exit 1
pause
Thanks John. Waiting to hear from him.
Silku wrote:
Thanks John.
try
try
# Connect
# Format timestamp
$session.GetFiles(
finally
$session.Dispose()
exit 0
catch [Exception]
#exit 1
pause
bgolfer66
United States
You may want to check that you should be using FTP Secure and not SFTP
and if it is FTPS, is TLS the proper security?
Silku wrote:
Thanks John.
try
try
# Connect
# Format timestamp
$session.GetFiles(
finally
$session.Dispose()
exit 0
catch [Exception]
#exit 1
pause
Please start a new topic and attach a full session log file showing the problem (using the latest version of WinSCP).
Silku
Tryingto create Session log but it is not doing anything...
Although through GUI, it is creating the session log.
What I am missing..
$session.DebugLogPath = $WinSCPDebugLogFile
$session.SessionLogPath = $WinSCPSessionLogFile
$session.XMLLogPath = $WinSCPXMLLogFile
Silku
Session log created getting 331 Password required for
2014-07-11 10:47:42.098 331 Password required for
> 2014-07-11 10:47:42.098 PASS ********
< 2014-07-11 10:47:42.119 530 User cannot log in.
. 2014-07-11 10:47:42.119 Connection failed.
. 2014-07-11 10:47:42.120 Password prompt (last login attempt failed)
Re: Session log created getting 331 Password required for
I do not know how to help you. Are you able to connect from GUI? It seems like your username/password is wrong or the account is disabled.
Silku
Yes, Martin, with same configuration I can able to connect with GUI...
Sriram
Session.Open(Sessionoptions) getting error
Dear All,
Actually i m using secure ftp, I am using winscp to push the file to sftp, but in session.open i am getting error. i gave ftpurl, hostname, username and password, but i never give sshostFingerprintkey, instead of this i gave sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey = true; .. But not resolved. how i achive that.
Re: Session.Open(Sessionoptions) getting error
Sriram wrote:
Dear All,
Am using Asp.net with C# along with WINSCP
Sriram wrote:
i am getting error.
Would you mind telling us, what error is that?
Even better, start a new topic and attach a full session log file showing the problem (using the latest version of WinSCP).
