.NET: Mask to get today's file using ListDirectory method
Suresh
Malaysia
I am currently developing a VB.NET application and I wanted to list out all txt file today’s file available in SFTP folder. The application uses Winscp.dll (version 5.0.6.0).
I am passing *.txt along with the sftp path to ListDirectory method
Example: /Test/*.txt
It downloads all files available in the /Test/ folder with .txt extension, then I am looping through each file and checking the file date time and filtering today’s file.
I found there is a Mask feature where we can specify the date time.
Ref: https://winscp.net/eng/docs/file_mask
>yyyy-mm-dd[ hh:mm[:ss]]
Matches files modified the last time after the date or time (i.e. “newer than”).
>2012-01-01,>2012-02-29 08:47
But when I pass the File Mask to List Directory method, it is not supported.
/Test/*.txt>2014-02-21
I believe I am missing some points here, please help.
Code Snippet
Imports WinSCP
Try
   Dim sessionOptions As New SessionOptions
   With sessionOptions
        .Protocol = Protocol.Sftp
        .HostName = HostName
        .PortNumber = PortNumber
        .UserName = UserName
        .Password = Password
        .SshHostKey = SSHHostKey
    End With
   Using session As Session = New Session
      session.Open(sessionOptions)
      Dim directory As RemoteDirectoryInfo = session.ListDirectory("/Test/*.txt>2014-02-21")
   End Using
Catch e As Exception
     WriteInLogFile("Error : " & e.Message.ToString)
End Try
WinSCP
WinSCP 5.0.6 (Build 2074)
Kindly note that I don’t want to download the file.
Suresh
Reply with quote E-mail
Re: .NET: Mask to get today's file using ListDirectory method
That's correct, the Session.ListDirectory does not support file masks. You need to filter resulting file list yourself.
Suresh
Malaysia
Thank you for your response.
