System Error Code 3: during sync
flagcitysteeler
United States
I get the following error when trying to syncrhonize directories between local hard drive & WD MyCloud via ftp.
System Error. Code: 3.
The system cannot find the path specified
In the preview before sync, I can see that the local directory is always ".\"
and the remote is always "./" even for subdirectories.
I am running windows 7, in commander gui for latest statble release & also tried older version.
It doesn't matter what the local or remote paths are, they are always as shown above in the preview screen. It seems that this is what is causing because I don't have (or want) access to the root of the ftp. It needs to start in the folder specified. I must be overlooking something really basic & appologize.
Sincerely,
Yates
Description: Preview before error
Description: Options used
Re: System Error Code 3: during sync
The .\ and ./ refer to roots of the synchronization. So it's ok.
