Failure to completely transfer 8.9 GB file via FTP
bvb
Using WinSCP 5.5.1 Build 3970, connecting to FileZilla server 0.9.43beta, with straightforward ftp, I transferred a 9,407,966,459 byte file. Transfer went fine up to 8,437,830,012 bytes and then failed and would not successfully resume. If this isn't a known problem, I'll post any details requested. The transfer resumed successfully when I switched to the current Filezilla client, with no other changes.
Re: Failure to completely transfer 8.9 GB file via FTP
Thanks for your report. I was not able to reproduce the problem. Are you? Was it upload or download?
