updates
none
updates
when you choose 'never check for updates' it checks anyway with an annoying popup??????
thanks for fixiing this as if its not fixed i will either block it from internet or just remove it.
Re: updates
So you have selected Never option for Automatic check period in Preferences?
What popup do you get? Can you attach a screenshot?
