Central config file
eeprom
Central config file
is it possible to use one .ini-file for many users? Is it possible to edit the directory where winscp looks for the .ini-file?
Thanks,
Hans
Re: Central config file
Sure, use Preferences dialog to switch to INI file from default Registry.
Use /ini=path switch. I have just added this missing piece of information to About page.
