Remote command execution with single sign-on
vrkorada
I want to connect to unix hoist from my windows7 desktop and execute remote commands. I am able to do using Quest putty/ plink without typing any password using GSSAPI. However, Can I do the same using WinSCP?
Regards,
Venkat
vrkorada
Re: Remote command execution with single sign-on
Sorry for not clear in my question. I am looking for a .net library, so that I can use it in my application.
I couldn't find any option to use the same advanced settings to enable GSSAPI authentication.
Am I missing something? Can you share a code snippet to set the GSSAPI?
Regards,
Venkat
vrkorada
Thanks for reply. Rawsettings option is working. However, now I am getting error asking to set the hostkey.
Here is the snippet:
try
// Setup session options
Protocol = Protocol.Scp,
HostName = "host03.company.com",
UserName = "venkat",
//Password = "mypassword",
//SshHostKeyFingerprint = "ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
sessionOptions.AddRawSettings("AuthGSSAPI","1");
sessionOptions.AddRawSettings("SshProt", "2");
// Connect
session.Open(sessionOptions);
return 0;
catch (Exception e)
Console.WriteLine("Error: {0}", e);
return 1;
When I use the GUI tool WinSCP, it never asks me the host key and I never provided hostkey to plink also.
Am I missing something here?
Regards,
Venkat
vrkorada
With WinSCP UI / plink, when we connect to a host for hte first time, we get a prompt saying server's host key is not in cache and asking the confirmation to continue with caching hte key.
Is there any API for checking the availability of the key in the cache and if it not available, any API to get eh server's host key?
Regards,
Venkat
No.
You should not automate this. It would spoil security purpose of the verification.
Anyway, if you do not care about security, you can accept any host key with SessionOptions.GiveUpSecurityAndAcceptAnySshHostKey:
https://winscp.net/eng/docs/library_sessionoptions
