WinScp v5.5.0 build 3839 - Commander Transfer local to remot
Guest-Matos
Hi Guys,
This is to let you know that when performing commander transfer from local to remote
using drag 'n drop, target is not showing default directory being shown ending in /*.*
to copy using same name, if one have changed one name, it remains as default for
all subsequent transfers...
ie.
from name = test1 to name = test 2
from name = test3 to name = show "test 2"
(if you are not looking closely) you may overwrite test2 with test3 in remote side.
Thank you!
Re: WinScp v5.5.0 build 3839 - Commander Transfer local to remot
Sorry, I do not understand. Can you describe the problem step by step. Possibly illustrating it with screenshots?
