WINscp using a key
Pat Coburn
WINscp using a key
I am trying to establish a winscp session between my server and the university's server. they have input the public key on their end, but when I go to connect, it fails the key and trips over to the password. The exact message is:
. Reading private key file "E:\AISInterface\oraprivatekey.ppk"
. Unable to use this key file (SSH1 private key)
! Unable to use key file "E:\AISInterface\oraprivatekey.ppk" (SSH1 private key)
. Keyboard-interactive authentication refused
It is using scp as the transfer protocol.
Any assistance would be appreciated.
thanks.
Re: WINscp using a key
Note that SSH2 is the default SSH version in WinSCP and you are trying to use SSH1 key. Try to switch to SSH1, or better get the SSH2 key.
PeterGfader
Hi Pat
How can i switch to SSH1? From commandline or via .NET Automation?
If I use the winscp.ini file with the below section I can establish a connection
[Sessions\eaoload@srt20601ax]
HostName=myHOST
SshProt=1
PublicKeyFile=C:%5CUsers%5C.....
But I need to connect via .NET. (My 2nd not preferred option would be to start winscp via a new process..)
THANKS!
PeterGfader
I figured it out, via one of the forum posts...
--> sessionOptions.AddRawSettings("SshProt", "1");
It would be great to have this in the documentation!
