SFTP Connection - Session.Open; ERROR: Temporary File in use
Moneyblind
Hello! I am running into an issue; I have taken the overall example C# code and modified it to match my credentials and host account. However, the TEMPORARY file that is created by Session.Open is returning this error.
A first chance exception of type 'System.IO.IOException' occurred in mscorlib.dll
Additional information: The process cannot access the file 'C:\Users\Admin\AppData\Local\Temp\wscp24C0.0223CC89.tmp' because it is being used by another process.
Here is the code:
private bool uploadFile(string path, string hostName, string username, string password)
    try
        // Setup session options
            Protocol = Protocol.Sftp,
            HostName = hostName,
            UserName = username,
            Password = password,
            SshHostKeyFingerprint = "ssh-rsa 1024 **:**:**:**:20:8f:95:69:12:f5:52:**:**:**:**:**"
            // Connect
            session.Open(sessionOptions);
            // Upload files
            transferOptions.TransferMode = TransferMode.Binary;
            TransferOperationResult transferResult;
            transferResult = session.PutFiles(path, "/", false, transferOptions);
            // Throw on any error
            transferResult.Check();
            // Print results
            foreach (TransferEventArgs transfer in transferResult.Transfers)
                Console.WriteLine("Upload of {0} succeeded", transfer.FileName);
        return true;
    catch (Exception e)
        Console.WriteLine("Error: {0}", e);
        return false;
MichaelMotes
Same problem
I have this same problem, here is the callstack:
mscorlib.dll!System.IO.__Error.WinIOError(int errorCode, string maybeFullPath) + 0x321 bytes
mscorlib.dll!System.IO.FileStream.Init(string path, System.IO.FileMode mode, System.IO.FileAccess access, int rights, bool useRights, System.IO.FileShare share, int bufferSize, System.IO.FileOptions options, Microsoft.Win32.Win32Native.SECURITY_ATTRIBUTES secAttrs, string msgPath, bool bFromProxy, bool useLongPath) + 0x477 bytes
mscorlib.dll!System.IO.FileStream.FileStream(string path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) + 0x54 bytes
mscorlib.dll!System.IO.File.Open(string path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) + 0x25 bytes
WinSCPnet.dll!WinSCP.SessionLogReader.OpenLog() + 0xd1 bytes
WinSCPnet.dll!WinSCP.SessionLogReader.DoRead() + 0x64 bytes
WinSCPnet.dll!WinSCP.SessionLogReader.Read(WinSCP.LogReadFlags flags) + 0x86 bytes
WinSCPnet.dll!WinSCP.CustomLogReader.TryWaitForNonEmptyElement(string localName, WinSCP.LogReadFlags flags) + 0x5f bytes
WinSCPnet.dll!WinSCP.CustomLogReader.WaitForNonEmptyElement(string localName, WinSCP.LogReadFlags flags) + 0x29 bytes
WinSCPnet.dll!WinSCP.CustomLogReader.WaitForNonEmptyElementAndCreateLogReader(string localName, WinSCP.LogReadFlags flags) + 0x29 bytes
WinSCPnet.dll!WinSCP.Session.Open(WinSCP.SessionOptions sessionOptions) + 0x775 bytes
Re: Same problem
MichaelMotes
XP only
This error only occurs on my old XP dev machine. My new Win7 dev machine doesn't experience any issue with the same code. I suppose XP is official dead and dying.
Gurmeet
System.TypeInitializationException
This is happening when I am trying to compile VS 2013 solution
System.TypeInitializationException was unhandled
Message: An unhandled exception of type 'System.TypeInitializationException' occurred in mscorlib.dll
Additional information: The type initializer for 'XXXXX' threw an exception.
using (Session sess = new Session())
    //sess.SessionLogPath = @"C:\GUR";
    sess.Open(sessionOptions);
    //Get Ftp File
    transferOptions.TransferMode = TransferMode.Binary; //The Transfer Mode -
    transferOptions.FilePermissions = new FilePermissions(0666); //Permissions applied to remote files. 0666 is read/write
    transferOptions.PreserveTimestamp = false; //Set last write time of
    transferOptions.ResumeSupport.State = TransferResumeSupportState.Off;
    transferResult = sess.PutFiles(fileName, ConfigurationManager.AppSettings["SFTPToPath"], false, transferOptions);
Victor78
Shitty WINSCP
Fack you guys who made this shity winscp, I'm lost my 2 weeks job because i' used this crap program.
Isn't save anything just after few try because this is the full of Shlt software
Re: System.TypeInitializationException
@Gurmeet: What is the XXXX? Anyway, please start a new thread. I do not see how's your problem related to this topic.
Daniel Yanko
Fix - just ignore it
I had the same problem in my .NET Framework app and I found out that I can... just ignore that exception and click continue in debug -> goes further and session is opened.
