FileTransferProgress event still occurs
sendo
First of all, I believe that winscp is a better transfer tool than sharpssh or ssh.net : easier to use, better performance on large files, multi-protocol support
I also want to point out that when downloading one file (with filemask selection) among 50 000 files, Session.FileTransferProgress event still occurs even if FileTransferProgressEventArgs.OverallProgress is 1 (100%)
In the meantime it seems to continue browsing skipping files (please find the attached session log)
Unless I am mistaken, there are other operations during getfiles execution so i'm wondering how to calculate an accurate transfer speed ?
Any advice and support would be appreciated
Thank you
Re: FileTransferProgress event still occurs
What is an accurate transfer speed for this case? You are asking WinSCP to check over 50 thousands files, where only 1 is actually transferred. Do you want to calculate speed for that single transfer against time the transfer took or again time the whole operation took? Neither seems relevant to me.
