no additional language when using /loadinf
AF
WinSCP V5.5.1
I've saved the installationconfig with /saveinf=winscp.inf and loaded it in a new installation with /loadinf but the selected german language is ignored.
The components line in the inf-file contains:
Components=main,shellext,pageant,puttygen,transl,transl\de,transl\eng
Normal non-silent installation installs the additional language.
Any ideas? Bug?
Best regards,
Alex
Re: no additional language when using /loadinf
It works for me.
Do you mean that winscp.de is not installed or that German language is not used when installed WinSCP is started?
Can you attach a installer log file?
