WinSCP silent install stop putty/filezilla import question?
csjjpm
is there a command line option or entry for default.inf to prevent the popup that asks if I want to import from putty and filezilla?
thanks
Paul
Re: WinSCP silent install stop putty/filezilla import question?
https://winscp.net/tracker/1112
The only workaround now is to set following registry key prior to install:
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface]
"AutoImportedFromPuttyOrFilezilla"=dword:00000001
