Errorevent Running .NET-Powershellscript in Sched-Tasks
lellerkamp
Dear Sir or Maddam,
I'm using the .NET assembly in Powershellscript to exchange files between a Windows Server 2008R2 an 2 Unix machines via SCP/SFTP.
First I get the files from a Unix machine to W2k8R2 via SCP. Later they will be putted on a HP-UX machine via SFTP.
If I run the script manually, the script completes without any errors. If I run the script via Scheduled Tasks (The local admin is defined to run the task), a error will be created in Event Viewers Queue "Application" -look for Error below-.
In both cases, the filetransfer works great, so I don't know why the error is shown.
Queue: Application
Source: Application Error
Name der fehlerhaften Anwendung: winscp.exe, Version: 5.5.0.3839, Zeitstempel: 0x00000000
Name des fehlerhaften Moduls: winscp.exe, Version: 5.5.0.3839, Zeitstempel: 0x00000000
Ausnahmecode: 0xc0000005
Fehleroffset: 0x002bf2a0
ID des fehlerhaften Prozesses: 0xb88
Startzeit der fehlerhaften Anwendung: 0x01cf141a050e0306
Pfad der fehlerhaften Anwendung: C:\Program Files\WinSCP\winscp.exe
Pfad des fehlerhaften Moduls: C:\Program Files\WinSCP\winscp.exe
Berichtskennung: 4382d468-800d-11e3-8497-00155d8e1904
I didn't found any troubleshooting information. It would be great, if I get help asap.
L. Ellerkamp
Re: Errorevent Running .NET-Powershellscript in Sched-Tasks
lellerkamp
The problem is solved :D
In the script, I've opened the connection some times, but I've not closed the session.
In TaskManager WinSCP.exe is running many times.
I dispose the session now at the end of the script and anything works great.
Martin, thanks for your fast reply.
