Login button icon: wrong, session tabs: wrong
Inuya5ha
Argentina
I just upgraded from WinSCP 4.3 to 5.5, and I like the new layout of the main login screen, but the green icon in the Login button threw overboard all the program seriousness and solemnity.
When a button is important, it's not iconized. Please remove the icon and just make the font bold, that is: Login.
Maybe the icon looks good on certain Windows version (not on XP) but again, the program does not look serious anymore. It's really depressing to see a great GUI spoiled.
Also: the session tabs should be relocated, either as the first row (below menu) or the last row, and its row should have a darked bgcolor since it's not a toolbar, it's a tabs bar. Now they look worse than IE 6 with tabs support added by the MSN Toolbar. I know I can move the tabs, but why not take care of these details before launching the final stable version to benefit everyone? :?
You may say these are tiny details, but it's remarkable how these can ruin a once admirable GUI. That's exactly the reason why I was always reluctant to check for updates: I was afraid this would happen.
Re: Login button icon: wrong, session tabs: wrong
Thanks for your post.
Where do you have the rule from?
Could you possibly share a screenshot? Maybe it looks different on your system. It definitely does not look that well on Windows XP as on newer systems, but I do not consider it that bad though.
The tabs have standard Windows tab color.
They are located above a part of the window they are changing (file panels). I believe that's the correct place.
Just as in web browsers: Above webpage and address bar, below menu.
