Timeout Detected
fabstr
Timeout Detected
Hi there!
i have a really annoying problem with WinSCP and Windows 8.1. When i transfer files (could be small or larger, doesn't matter) i get an error message:
Lost Connection: Timeout Detected
It can also happen that files with size zero are stored.
I already updated to the latest version of WinSCP, put FTP in passive mode but nothing helps.
I really need this working :)
can anybody help?
Re: Timeout Detected
Also please register, so we can send you a debug version of WinSCP, if needed.
fabstr
Germany
ok thanks for your answer.
attached is an log file. I tried to delete a folder with some files included and after while processing it got stuck with the timeout.
Description: WINSCP log
PC-Gram
Same story here
I experience the same problem. Whenever I have used the program for some time I get time out. It occurs on a very regular basis and seems not to be related to what I am doing or how many bytes I transfer.
However this problem only appears on my 2 Win7 machines. Not on my old XP.
My current workaround is to set the reconnect time as low as possible.
Re: Same story here
PC-Gram wrote:
I experience the same problem....
I need to add that the problem seems not to be related to any version of Winscp.
I have attached a typical part of my log where a timeout occurs
I do not see any transfer in the log. Only deleting of files. But the problem is there. So I assume it happens during any operation, not just transfer, right? Do you have the problem with other FTP clients?
Re: Same story here
The same question, are you getting this problem with other FTP clients?
PC-Gram
Re: Same story here
I only get the problem with winscp and I can confirm, that it seems not to be related to transfor only.
PC-Gram
Further clarification
As I've mentioned before the problem is not only related to file xfers.
When it occurs, and it occurs every 10 secs or son when copying many files, I first get a windows system message "(not responding)" and the after 3-4 secs I get the "lost connection" message followed by a fast reconnection.
fabstr
Germany
That's exactly what i am dealing with. So far i just occurs in Windows 8.1...same version of WinSCP but Win 7 works fine
PC-Gram
Timeout server related
I have now changed to another hosting company and voila: My timeout problems disappeared indicating that the problem lies within the server WinSCP connects to.
I will investigate this further and come back.
PC-Gram
Re: Timeout server related
The server causing the troubles run proFTPD. Allegedly a known problem when running winSCP against proFTPD.
Tehej
I have the same problems since Windows 8.1. No matter if I upload, download or delete files. Anyway I tried other FTP clients and they had the same problem. I also use WinSCP on my private machine at home with Windows 7 installed with no problems. So it has to be an issue with Windows 8.1 in my case.
I tried anything I found like deactivating IE11 (it seems I can't deinstall IE on a german Windows...), deinstalling KB2909921 and also new drivers for nearly everything... Nothing fixed this issue :(
Tehej
Sry, forgot smth... It seems that only FTP connections are affected. Whenever I can, I use SFTP and that's working very well.
