If/Else Logic in Script
noochi01
USA
Hi Guys,
I would like to take two of my scripts one step futher and need some assistance. I'll provide my examples below, but first a very quick explaination. AND, I'm extremely new to WINSCP scripting....
I wrote a batch file that runs on an internal server with winscp installed, that calls a .txt file I've written with scp code. This code connects to a server in my DMZ (ftp server), and then successfully copies a specific file from my ftp server to a different internal server. After it copies the file internally, it finally deletes the file on the ftp server. All of that works perfectly. What I'm looking to do is add an if else statement, or some sort of logic so that if it finds the specific file on the remote server (ftp server), then perform the internal copy. If it doesn't find any file, I want it to close out properly.
Script that calls WINSCP and passes my FromFTPServer Script
start "" "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console /script=C:\WINSCP_Test_Scripts_12_22_13\FromFTPServer.txt
/log="C:\WINSCP_Test_Scripts_12_22_13\FromFTP.log"
#PAUSE
FromFTPServerScript
open sftp://Username:password@LocalFTPServerinDMZ
cd /home/User01/incoming/
option transfer binary
lcd \\InternalServer\InternalDirectory
get INCOMINGTESTFILE.TXT INCOMINGTESTFILE.TXT
rm /home/User01/incoming/INCOMINGTESTFILE.TXT
So, I need assistance adding some logic to this so that, if INCOMINGTESTFILE.TXT exists, then copy locally and delete. AND, If INCOMINGTESTFILE.TXT doesn't exist, then exit gracefully.
Any thoughts on how I can make this happen?
Thanks in advance,
Mike
noochi01
USA
Update!
Hi Guys,
I figured it out, and unlike so many other threads that I see on the web, I'd like to post a solution to help others who are new like me, and might face a similar situation. Full code is in my previous thread.
SO, in order to avoid errors in my script from files not being present, I first check to see the file exists. If it does, then I proceed...
IF EXIST \\InternalServer\InternalDirectory\FILENAME.TXT start "" "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console /script=C:\WINSCP_Test_Scripts_12_22_13\FromFTPServer.txt /log="C:\WINSCP_Test_Scripts_12_22_13\FromFTP.log"
If the internalserver file exists, then it proceeds to call WINSCP. If the file doesn't exist, then the script closes. Works great through all of my tests.
Also, I was unaware of these two commands previously, but am using them now. They allow me to perform an overwrite, and then copy a file and delete the source file after copy.
get INCOMINGTESTFILE.TXT INCOMINGTESTFILE.TXT -delete
FromFTPServerScript
I hope it helps!
Mike
noochi01
USA
Scheduled batch not running when logged off
Thanks for sharing your solution.
Anytime! I have a follow-up Martin and need some assistance....
I'm running WINSCP on Server 2003, moving files back and forth between my internal network and DMZ network. I'm accomplishing this through scheduled jobs that call my batch files which in turn call my script. Everything works perfectly. I can launch the batch files manually, and they perform as expected, I can schedule the batch jobs, and again they peform as they should. The issue I have now identified, the last piece of the puzzle, is that when I log off the server, the jobs no longer run. If I Remote Desktop to the server, and click the X to kill my session, the jobs still run because technically my profile is still logged on. Any idea of how I can have the scheduled jobs continue to run while logged off? This I thought would have been the easiest part of this process!
My scheduled job calls this batch file:
#PAUSE
FromFTPServer.TXT Contents:
open sftp://LOCALUSERNAME:PWD@IPADDRESS
cd /home/LOCALUSERNAME/incoming/
get INCOMINGFILE.TXT INCOMINGFILE.TXT -delete
#end script
#close
Works perfectly while logged in. I included all code, but really I think it's something with the actual batch file being called. The Run As is a local admin and has full access to all directories.
Any asistance is greatly appreciated!!!!
Thanks,
Mike
Re: Scheduled batch not running when logged off
Please read FAQ:
https://winscp.net/eng/docs/faq_scheduler
If that does not help, attach a full log file showing the problem (using the latest version of WinSCP).
noochi01
USA
[quote="prikryl"]
noochi01 wrote:
Please read FAQ:
Hi Martin,
Thank you for your reply. It looks like it's reading the registry. I'm adding two attachments- one for each script that I'm attempting to run while logged off, but both fail to execute. These logs were generated while logged in. When logged off, the scripts don't get called, therefore nothing is added to the log files.
Let me know what you think. Verison 5.50 (Build 3839)
Thanks,
Mike
Description: Log Sending to the FTP Server
Description: Log Pulling from the FTP server
noochi01
USA
Hi Martin,
Any thoughts on why this wouldn't be working? I still haven't been able to resolve this yet.
Thanks,
Mike
OK, I may understand finally. So it's nothing to do with WinSCP right? It's just that the Windows Scheduler does not start you task. Maybe you have Scheduler's task option Run only when user is logged on selected?
