Downloading files modified today or within last 2 hours
ichayan
I am using winscp to download files from a unix server. I need to download files which are created on that day and /in the last two hours, there are files from at least ten days in the directory. The files doesnt have any extension. file names are a series of numbers. I can only connect to the server using FTP protocol.
I used the file mask and and tried
get *>2h
and
get *>2014-01-16
its downloading everything in the directory in the GUI i can see there are files with time stamps from 07-01-2014 onwards
Also is there a way to search for a string in the files on the fileserver and download only those files which has the string in it.
E45OPQ
Re: Downloading files modified today or within last 2 hours
Your syntax is correct. Make sure you are using the latest version of WinSCP.
If you are, please attach a full log file showing the problem (using the latest version of WinSCP).
I do not think there's any way to search file contents with FTP protocol, without downloading it.
