Port configuration and session timeout problems
horrendoKbum
An automated winscp script has been working between two servers in both directions for 6 months.
From last week, at a random file(both directions), session is interrupted. I tried a 'timeout' but it results in a recursive error, i mean, first time the script reconnect, the forth or fifth file again stops the session, after that, the first or second file do it and finally the app is not capable to start session, sometimes it becomes an infinite loop, sometimes it results in Winscp-APPCRASH.
There have been some kind of port configuration somewhere because from last week, the only way to avoid a
'Can't open data connection' error is setting the task as 'active' although it was working as 'passive' for 6 months, but the main problem with connection continue.
Re: Port configuration and session timeout problems
What version of WinSCP are you using?
Are you using SSL/TLS?
What is your FTP server?
Thank you
WinSCP Version 5.5.0 (Build 3839) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Enterprise)
No SSL , no TLS
Theres no email address in your profile
