automation error VBA
utb2b
Hi Support,
I have got simple VBA program which help us to download files from SFTP server. It's working perfectly in mostly in all machines.
when I try to use the same excel in particular machine it throws automation error.
OS: Windows 7
WINSCP version: winSCP 5.1.7
we tried to uninstall winscp and unregister the tlb and dll. we try to install again and getting same error Automation Error. (object variable is not set.
below is the code.
Dim SFTPSession As New session
Dim SFTPSessionOptions As New sessionOptions
With SFTPSessionOptions
.Protocol = Protocol_Sftp
.HostName = txtHN.value
.UserName = txtUN.value
.password = txtPWD.value
.portnumber = txtPort.Value
.SshHostKeyFingerprint = txtHostkey.value
End With
SFTPSession.Open SFTPSessionOptions
Thanks in advance for your help and support.
Thanks,
utb2b
Re: automation error VBA
On what line does it throw?
Did you use a different version of the assembly on that machine before? It you did, did you unregister it?
utb2b
Thanks for your response.
in the above line it pops up Automation error.
Actually I was using winscp 5.1.7 . Yesterday, we tried to uninstall winscp 5.1.7 and unregister dll and tlb. we tried to install a winscp 5.5 and registered winscpnet.dll successfully. manual interface of winscp is working on that machine. But VBA macro pops up the same error message on the same line.
With SFTPSessionOptions .
Thanks in advance.
