GUI does not display all remote directories
slim3000
When I access the remote host using the GUI (Commander), I am not able to see all of the same directories that are available when I connect via the command line. I am using the same session/credentials for both connections. Is there something that needs to be configured for the GUI?
Thanks,
Me
Re: GUI does not display all remote directories
