We believe the server has signed timestamps bug
Prasad_sri
India
Re: We believe the server has signed timestamps bug
Hi Administrator or Moderator, please hide this post ASAP.
Please reply answer to email id prasad_ksk_sri@hotmail.com
inder
Error message from server: No such file
Hi there
I am using WinSCP Version 5.7.4 (Build 5553) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Enterprise).
I have an issue with the WinSCP program in UPLOADING files although the downloads seem to work OK.
Please find the ERRO logs below:
"Status code: 2, Message: 7689, Server: No such file, Language:
* 2016-06-08 05:00:13.311 (ETerminal) No such file or directory.
* 2016-06-08 05:00:13.311 Error code: 2
* 2016-06-08 05:00:13.311 Error message from server: No such file
. 2016-06-08 05:00:13.327 Asking user:
. 2016-06-08 05:00:13.327 **Upload of file '20160608015837_3969941000542.csv' was successful, but error occurred while setting the permissions and/or timestamp.**
. 2016-06-08 05:00:13.327 If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option. ("No such file or directory.
. 2016-06-08 05:00:13.327 Error code: 2
. 2016-06-08 05:00:13.327 Error message from server: No such file")
< 2016-06-08 05:00:13.327 Script: Upload of file '20160608015837_3969941000542.csv' was successful, but error occurred while setting the permissions and/or timestamp.
< 2016-06-08 05:00:13.327 If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option.
< 2016-06-08 05:00:13.327 Script: No such file or directory.
< 2016-06-08 05:00:13.327 Error code: 2
< 2016-06-08 05:00:13.327 Error message from server: No such file
* 2016-06-08 05:00:13.327 (EScpSkipFile) **Upload of file '20160608015837_3969941000542.csv' was successful, but error occurred while setting the permissions and/or timestamp.**
* 2016-06-08 05:00:13.327 If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option.
* 2016-06-08 05:00:13.327 No such file or directory.
* 2016-06-08 05:00:13.327 Error code: 2
* 2016-06-08 05:00:13.327 Error message from server: No such file
. 2016-06-08 05:00:13.327 Script: Failed
. 2016-06-08 05:00:13.327 Script: Exit code: 1
. 2016-06-08 05:00:13.327 Closing connection.
. 2016-06-08 05:00:13.327 Sending special code: 12
. 2016-06-08 05:00:13.342 Sent EOF message
. 2016-06-08 05:15:02.198 --------------------------------------------------------------------------
. 2016-06-08 05:15:02.198 WinSCP Version 5.7.4 (Build 5553) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Enterprise)
. 2016-06-08 05:15:02.198 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\"
inder
melbourne
Timestamp bug
Hi there
I am having the same issue while uploading the data. Downloading is OK though.
I am currently using WinSCP Version 5.7.4 (Build 5553).
If you could help me in any way that would be appreciable?
thanks
inder
Re: Timestamp bug
Hows this related to this thread?
Anyway, see
https://winscp.net/eng/docs/message_preserve_time_perm
Particularly this part:
Some servers are set up to pickup any uploaded file immediately, process it somehow and delete or move it away. If the server is quick enough, it does that before WinSCP is able to update the file timestamp or permissions (you will see an error like “No such file or directory” in error details).
