5.5: Suggestion for dropdown "save as" dialog
Pathduck
Pathduck avatar
Oslo
Hello Martin :)
I have a suggestion for the dropdown dialogs in the new session management interface.
Here's my problem, I do this a lot:
- Select existing session, often in a folder
- Choose Edit and change hostname.
- Choose Save As and change just the name of session (user@hostname), so the folder is the same.
This behaviour is different from the "Clone" option since it lets you save in the same folder as the old session. I have a lot of folders and sessions for different environment and do this quite a lot so am dependent on a quick way of doing it using the keyboard.
My suggestion:
- Change shortcut for "Save As..." to ALT+A, which is consistent with standard Windows conventions.
- Change shortcut for "Advanced" to ALT+D, which is also pretty logical and should not interfere with other commands.
This way, I could quickly choose Save As when finished editing a new session.
Hope you can have a look at this, and wishing you all the best for the holidays and a Happy New Year! :)
-Stian
Re: 5.5: Suggestion for dropdown "save as" dialog
Thanks for your suggestions. Will do.
Also the Clone command may actually remember the folder (and even site name).
Pathduck
Pathduck avatar
Oslo
Wow, that was fast :shock:
Thanks a lot Martin, tried the dev build, works like a charm :)
It will be much easier to do this stuff with the keyboard shortcuts now.
cheers,
Stian
Leora45
Portugal
Niiiice ! I was just about to create a thread to ask for this improvement !
Thanks for the so fast implementation :wink:
Leora
I have sent you a download link via email too.
