Closing the shell command after running a myScript.bat file
sy272951
I run a command line login to an sFTP site + synchronizing local folder against the remote one with a mask
Two outstanding issues
a) could not figure out a way of "comparing" be limited to the remote (folder) /OUT that I want... it basically goes creates similar folder structure locally at /ROOT level and scans thru all folders under the /ROOT while /OUT is being just one of them.
b) After the synch process.... the command window sits with
winscp>
even though I tried "exit" and/or "quit" at the end of the command line.
So, I cannot close the command window during the automated downloads
I know these are simple issues.... but any help will be so appreciated.
Best Regards
Cornelia / Boston, USA
sy27295
Boston, USA
Re: Closing the shell command after running a myScript.bat file
"C:\Program Files (x86)\WinSCP\WinSCP.com" /command "option batch abort" "option confirm off" "open sftp://MYUSERID:MYPASSWORD@SFTPSITE.REMOTESERVER.ORG" "cd /OUT" "synchronize LOCAL \\cornelia1\e\data\irxData\OUT /OUT -filemask="*_REJECT_*""" "exit"
This is what I am sending to the command shell window, but it stays at
winscp>
... after resyncing with local directory.
I want it to get out of winscp to
C:\>
so that the CMD window will close (or will be closed by the running VB script).
Best Regards
Reply with quote E-mail
winscp>
You seem to have quotes wrong. You should have double double-quote after the -filemask=. I.e. the trailing part should be:
-filemask=""*_REJECT_*""" "exit"
