simultaneous use of command line and gui instances
KenH
v5.5 / win 7-32
I have an instance of WinSCP running every 60-seconds from the Windows task scheduler. Are there any considerations/issues if I were to open the GUI and initiate a session to another server, concurrently?
Thanks for the program. I just switched from FZ because of directory listing issues with Comcast. WinSCP works fine!
Ken
KenH
Is the following command line string sufficient to isolate instance?
/command "option batch abort" "option confirm off" "option transfer binary" "open ftp://xxxx@xxxx.com" "put ""c:\program files\xxxx\archive\xxxx.jpg""" "exit"
Re: simultaneous use of command line and gui instances
No. You need to use /ini=nul switch or use isolated INI file.
KenH
I added /ini=null to the command line and it failed to execute. I also tried creating a script using the same commands that are in the command line string, and it also fails. Both are being triggered by the Windows Task Scheduler.
What am I doing wrong?
KenH
As you suggested, I used the log file to troubleshoot. The problem was that I was not passing my password to the server, in the command line. Everything is working fine, now. :-) Thanks!
