direct link to files, sftp://user1@sftp.server.com/testfile.zip
bobsmith
hi, i know that winscp is registered to open sftp:// and scp:// links, but can it be used to directly download a file if given this url?
or
scp://user1@sftp.server.com/testfile.zip
i have a passwordless private key so i can login without having to supply a password. is there any way to do this? i'm modeling it after the standard ftp://ftpusr:passwd@ftp.server.com/file.zip.
right now, if i set up a web page with the link above (scp://user1@sftp.server.com/testfile.zip), it opens winscp, i get prompted for my password, and then it says it can't cd to the testfile.zip directory. i'd like it to recognize my private key, and start downloading the file immediately like a normal http download. any ideas on if this will work? thanks, bob.
Re: direct link to files, sftp://user1@sftp.server.com/testfile.zip
WinSCP cannot handle URL's pointing to file yet. But it is already on the wishlist :-)
winscp3.exe [(scp|sftp)://][user[:password]@]host[:port][/path]/[filename]
That would be great if we can have the additional commandline and not having to interactively mget/get a file:
winscp3.exe [(scp|sftp)://][user[:password]@]host[:port][/path][filename]
Re: winscp3.exe [(scp|sftp)://][user[:password]@]host[:port][/path]/[filename]
Scripting/automation feature is on current user poll, you may add a vote.
Mohit
How to use Paswordless WINSCP through Command prompt
i hav private key which is working fine
with winscp GUI but i hav to do this using command prompt.
so i m trying this command
c:/downloads/winscp374.exe /console /script=c:/pritest.bat sujan@10.122.108.25 privatekey=c:/test_linux.ppk
but it still asking for pasword..
UREGNT.....
Mohit
i tried this
c:/downloads/winscp374.exe /console sftp://user@server /script=c:/pritest.bat /privatekey=c:/test_linux.ppk
again asking for password
Mohit
Re:Re: How to use Paswordless WINSCP through Command prompt
i tried this
I'm not sure if forward slashes may not cause a problem. In any case, please post a log file.
