Incorrect download 550
sunrisecc
Toronto, Ontario
On two computers, Win 7 and XP, using direct download, I am getting the file without the .exe attached to the name. Using the alternative location, I get the correctly named file.
_________________
Seymour
Re: Incorrect download 550
Thanks for your report. What web browser are you using? Do you have direct Internet connection or are you behind some kind of proxy?
sunrisecc
Toronto, Ontario
On the Win 7 computer, I am using IE11. On the XP computer I am using IE8.
No proxys etc.
I just tried FF and it works okay.
I am selecting the installation option.
PS. If I append '.exe' to the file downloaded by IE, it is a valid file.
sunrisecc
Toronto, Ontario
Using IE11 and selecting 'save as' and typing the full file name also works.
I also tested version 440 and it is the same as above.
Sourceforge is okay.
_________________
Seymour
