Syncronise automation doesn't update files
guest_Benoit
Hi there,
I'm trying to syncronise a folder in my FTP server with a local folder.
So, I use scripting method.
@echo off
WinSCP.exe /console /script=script_syncro.txt
There my script :
open sftp://benoit:****@***.***.***.***
synchronize local -mirror -delete "C:\Users\Benoit\Cloud" "/home/cloud"
keepuptodate "C:\Users\Benoit\Cloud" "/home/cloud"
As you can see, I start an update of my local folder from the server and then, I keep up to date the server with the local folder.
It seems perfect to me, but when I start the script : ok, It check all differences :
Then, It say :
But, I have :
And, If I modify the local folder like that, It doesn't work more (I update FTP client before taking screenshot) :
At least, It detect that I modify the folder... but doesn't upload.
Thanks in advance :)
Re: Syncronise automation doesn't update files
Thanks. But I need a log file for a session, when a change happens. I do not see any Change in ... detected record in the log.
BCrisvay
France
Ok, I do it again.
Ok, first :
I add a file called test_file_from_remote.txt in the remote /home/benoit/cloud/test/.
I start my script:
Line 36 803:
< 2013-12-19 19:10:04.971 Script: Synchronizing...
. 2013-12-19 19:10:04.972 Synchronizing local directory 'C:\Users\Benoit\Cloud\test\' with remote directory '/home/cloud/test/', params = 0x1007 (Delete, NoConfirmation, ExistingOnly, Mirror)
> 2013-12-19 19:10:04.972 Script: keepuptodate -delete -transfer=automatic -filemask=|films/;__pycache__/ "C:\Users\Benoit\Cloud" "/home/cloud"
It display "Script: Synchronizing...", but I have a file in the remote directory and it's not downloaded here...
I add a file in the directory C:\Users\Benoit\Cloud\:
36 809:
< 2013-12-19 19:15:38.085 Script: Change in 'C:\Users\Benoit\Cloud' detected.
36 844:
< 2013-12-19 19:15:38.610 Script: Change in 'C:\Users\Benoit\Cloud\test' detected.
36 848:
. 2013-12-19 19:15:38.610 Local file 'C:\Users\Benoit\Cloud\test\test_file_from_local.txt' [2013-12-19T18:03:37.654Z] [0] included to synchronization
Then, it find the new file I have uploaded before in the remote:
36 863:
. 2013-12-19 19:15:38.624 Remote file '/home/cloud/test/test_file_from_remote.txt' [2013-12-19T18:09:22.000Z] [13] is new
And delete it ...
36 866:
. 2013-12-19 19:15:38.624 Deleting file "/home/cloud/test/test_file_from_remote.txt".
Finally, none of these files are transferred.
You can download the full logs in attachment and looking around lines 36 8xx for all informations.
Thanks.
The reason is that you have Existing files only option enabled (in GUI):
. 2013-12-19 19:15:38.624 Synchronizing local directory 'C:\Users\Benoit\Cloud\test\' with remote directory '/home/cloud/test/', params = 0xBF (Delete, NoConfirmation, ExistingOnly, NoRecurse, UseCache, DelayProgress, SubDirs)
I suppose that you run 5.5 with different configuration (INI file).
The best is if you isolate your script run from GUI configuration. See:
https://winscp.net/eng/docs/scripting#configuration
