Optimize connection buffer
lost
Hi i get to the page were i can turn off the Optimize connection buffer but it will not change and info in that page!!!! I need to turn off the Optimize connection buffer and can't ???
Re: Optimize connection buffer
Sorry, I do not understand. Are you trying to turn the option off, but the setting does not persist?
Reyam
how can I turn off the optimize connection buffer option using command line?
sample line is:
/console /command "option batch abort" "option confirm off" "open sftp://username:pw@host:21 -rawsettings SendBuf=100" "cd /in/" " put C:\Users\Reyam.Cruz\Desktop\test.txt " "exit" "/log=C:\SSIS_Packages\BackEnd Objects\Log\WinSCP_log.txt"
Im using this in ssis execute task.
